Pushrod diameter decision
Discussion in 'High Tech Retrofits' started by 70PTRS, Aug 6, 2014.
  1. 70PTRS
    70PTRS Veteran Member
    257
    Aug 23, 2013
    Northern Illinois
    Alrighty I'm currently putting together my motor, here's the specs:
    02 5.7 stock bottom end
    243's full cnc porting 226cc by AI, milled to 61cc
    226/234 113 LSA 600/600
    Stock rockers with trunnion upgrade
    Ls7 lifters
    BT springs
    Ls6 manifold
    Should manage around 440-460 rwhp
    I measured with the pushrod checker last night and I'm going with 7.300 length pushrods. I get 4130 chromemoly 5/16 x .080 wall thickness pushrods with my order from Ai but read where a larger dia pushrod is much more robust for valve geometry. Is going to a 11/32 dia or 3/8 dia worth the extra cost or is it overkill for my motor? I'll probably take the car to the strip a couple times a year, shifting around 6500 rpm.
    I could have had them open up the hole for more clearance but wasn't aware of the larger pushrod dia at the time.
    Going to an 11/32 dia PR would cost 80-100 bucks more than the 5/16s
    I want to order them tomorrow so quick opinions are much appreciated
  2. TheMeat
    TheMeat Veteran Member
    970
    Feb 9, 2007
    Ol' Miss.
    I've got the 5/16 in my junk.
    BTR springs and cam.
    Doesn't look like you have anything crazy in it lift or spring pressure wise. I would run with what you got.
  3. 71RS/SS396
    71RS/SS396 Veteran Member
    2,624
    27
    Aug 26, 2008
    Wake Forest NC
    I would stick with the 5/16's, bigger is stronger but also heavier which is never good when it comes to valvetrain components imho.
  4. mrvedit
    mrvedit Veteran Member
    1,355
    Jun 12, 2009
    Ann Arbor, MI
    I have COMP 5/16 with dual valve springs with 400lb open pressure on cam with .624 lift. I have revved this to 7000 RPM hundreds of times.
    If I had 500 lb open pressure I would get stronger push rods.
  5. APEowner
    APEowner Veteran Member
    646
    11
    Dec 9, 2013
    Albuquerque, NM
    You probably already ordered them but you'll be fine with the 5/16" pushrods with that cam and those springs.
  6. 70PTRS
    257
    Aug 23, 2013
    Northern Illinois
    Nope; didn't order them. Will use the extra 100 bucks for something that makes more sense.
    5/16's it is.
    Thanks for the help :)
  7. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
    dont need bigger diameter pushrods unless your running crazy high spring pressure, you shouldn't be at 500hp
