Putting a Serpentine System on My '78 Z
Discussion in 'High Tech Retrofits' started by PFZ28, May 1, 2011.
  1. PFZ28
    PFZ28 Veteran Member
    472
    Dec 6, 2009
    ThornTown, Colorado
    One thing still not quite complete on my setup - external braces. How important are those? I've found one that fits from the belt tensioner to the water pump. All the other braces I found simply wouldn't go where I needed them to. Is there a way to make my own, or a supplier of typical ones?
  2. toadyoty
    toadyoty Veteran Member
    185
    Feb 21, 2011
    Stanwood, WA
    Good God people.......why do this to yourselves?
  3. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    I supported the back of the AC compressor, but not the alternator. Those were the 2 that came with my set up.
  4. PFZ28
    472
    Dec 6, 2009
    ThornTown, Colorado
    Thanks, Philip. I'll keep an eye out for a brace like that. I like the spacer too.
  5. 73RSZ/28
    73RSZ/28 Veteran Member
    233
    Aug 26, 2008
    St. Peters, MO
    What did you have to do with the A/C lines?
  6. Philip
    1,807
    May 30, 2006
    Marana, AZ
    The spacer and bolt came in the kit. There was a brace for the alternator also but I had to clock it differently for the main terminal to clear the tall valve covers and lost access to the mount hole for it.
    The AC manifold is for a Chevy truck. The tech used it so the valve covers could be removed without moving the compressor. The lines then run over the shroud and connect to the condenser.
    I had it all done at a local AC shop. Excellent work and reasonable pricing. Charged with 134A it will get as cold as the AC in my 06 GMC.
  7. PFZ28
    472
    Dec 6, 2009
    ThornTown, Colorado
    Haven't tried to solve that one yet. I'm very encouraged that it should be possible. I got a definite "Fssst" when I uncorked the S-10's AC system, so I believe it should work if I figure out how to get it hooked up. I noticed that the aluminum hose fitting from the '78 will bolt right up to the new AC compressor. However, my tall valve covers prevent it from getting all the way down. AND, the compressor is now on the other side of the car.
    Thanks for your pics and notes, Philip - that gives me encouragement. I don't know why I hadn't thought of taking it to an AC shop. That's probably what I'll do.
    <Wups> I was deleting my AC Delete comment while you were commenting on it. Lol. Re-edited my post to put this back in...
    Well, if nothing works out, I also picked up an AC delete pulley.
  8. Philip
    1,807
    May 30, 2006
    Marana, AZ
    AC delete :eek: well for me AC is very important, I am getting old and like my creature comforts.
    The hoses, orifice tube, accumulator, system flush, cycling switch, a little wiring, all labor and a charge of 134A was under $400.
  9. Yukon
    Yukon New Member
    Jan 19, 2020
    How did you determine the depth to drill into the head for the bolt?
    Thanks, Ryan
  10. biker
    biker Veteran Member
    995
    114
    Dec 7, 2014
    New Liskeard Ontario Canada
    Nice work! Excellent write up.
