Putting a Serpentine System on My '78 Z
Discussion in 'High Tech Retrofits' started by PFZ28, May 1, 2011.
  1. badazz81z28
    17,122
    552
    Las Vegas, NV
    I’m surprised to see you had to drill. A 3rd gen serpentine was a direct bolt on for my 78z
  2. dave@ztech
    3,510
    718
    Mar 27, 2016
    NY
    The thread is from 2011, and he used old heads, one's that didn't have the holes, great thread !
  3. BonzoHansen
    19,495
    824
    Jun 1, 2005
    Scott from Hamilton, NJ
    I run a 3rd gen setup. My old heads didn't have that hole. i just ran without that bolt, no problem. My new AFRs have that extra hole so in added those bolts.
  4. CorkyE
    10,445
    506
    This is a note from instructions that came with my GM kit;
    Note: Depending on which cylinder head is being used, Bolt 14091547 may not be able to be installed. If this bolt
    cannot be installed, continue on to the next stage. The system was tested without this bolt installed and no problems
    were noted.
    BonzoHansen likes this.
