Putting in a lt4 engine, just making sure I have my ducks in a row.
Discussion in 'High Tech Retrofits' started by SPG, Oct 3, 2018.
  1. SPG
    SPG Bumblebee Builder
    330
    54
    Sep 1, 2018
    Sacramento
    Hey everyone, I have a 75 camaro and alt4 engine with a 8L90-E trans and computer from a salvaged 2015 z06 and i just want to make sure I have the basics down before I start to tackle this major project.
    Before I go further I want to make 2 things very clear, already have the engine (was acquired unrelated to this project but it works out well) and I don't really want to sell it for something else, and I know there will be a lot of mechanical work involved in this that I'm prepared to handle with the help of my dad.
    Anyways I've done a bit of research on this but I want to make sure I'm not missing anything major before I proceed this weekend when I get everything in the mail.
    I ordered this kit and it seems to have everything I need to get started. I probably should have asked here if there was a better option....never too late to return things if you suggest I use something else.
    Is there anything else I should make note of for such a big project? Do you think I can use the rad from the corvette as well? or would I have to buy a new one. And are there any other brackets I should buy or little things that I'll probably need that I'm forgetting?
    Thanks for all the help everyone.
  2. SRGN
    SRGN Veteran Member
    673
    234
    Feb 20, 2009
    Central NJ
    The transmission won't work, it's designed to be rear mounted at the end of a torque tube in a Corvette application. You need one from a rwd truck/van or Camaro. Fuel system is another thing to start figuring out now. LT4 is direct inject, so fuel system needs to be able to support enough volume. I haven't used a BRP kit for an LT yet, their early LS kits had issues, hopefully they got the fitment sorted out. Beyond that, sounds like a fun project, good luck with it:bowtie:
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,370
    80
    Feb 2, 2008
    SF
    I used brp on my 69 camaro and they worked out great
  4. SPG
    330
    54
    Sep 1, 2018
    Sacramento
    Pretty sure that's the same trans they use in the current gen camaros as well...I can look into getting something else but I think that would mean I'd need a different computer as well.
    I'll do some research on the fuel system to make sure it will work with this project though, thanks for the info.
    thanks for the reassurance!
  5. Peck
    Peck Veteran Member
    631
    159
    Mar 20, 2018
    Tacoma,WA
    I am watching this, I would love to see it work. I don’t doubt it can be done, the first person to shove a sbc in an opel gt was told it wouldn’t work also, yet they used to be everywhere.
  6. Lowend
    14,958
    439
    Mar 25, 1999
    San Jose, CA, USA
    Yeah - Corvette transmission is a trans-axle which is Corvette specific. It really isn't practical for the F-Body as it's too wide for the factory tunnel. Bear in mind also that the driveshaft (torque-tube) spins at engine speed, replacing it with a different length isn't cheap.
    Might be worth a call to http://tildenmotorsports.com/ They make all sorts of cool LS/LT swap stuff and can help you with a harness and acquiring a take-out transmission
  7. SPG
    330
    54
    Sep 1, 2018
    Sacramento
    Alright thanks, I'll look into that if I still with the plan of a swap (might just rebuild the engine)
