Pypes exhaust hangers
Discussion in 'Engine Topic' started by Gipper, May 10, 2019.
  1. Gipper
    Gipper Veteran Member
    195
    Jun 29, 2002
    Rockwall TX
    I’m installing the SFG11 X pipe system. My question is for all that have this system installed. Did you actually drill holes in your floor pans to install the hangers to the mufflers??!! Is there anyone that built an alternative hanger ? Anyone successfully use the cross flow muffler mounts?
  2. Twisted_Metal
    26,492
    702
    I used the Thrush system (transverse muffler & "H" pipe, 2 1/2" system) and used the factory muffler hanger location to support the exhaust.
    I didn't want to drill holes in the floor pan either.
    The whole thing is hanging from the headers and the original transverse muffler hangers.
    No problems at all after 50K miles.
  3. Gipper
    195
    Jun 29, 2002
    Rockwall TX
    With the dual muffler system the tail pipe joint doesn’t align with the cross flow muffler mounts bracket. Time to get creative. I’m not putting holes in it, I’ll probable have to tack weld on home made brackets.
  4. Bandit723
    Bandit723 Veteran Member
    2,873
    385
    Oct 1, 2016
    Waupaca WI
    I have seen this setup. Uses the traverse muffler hangers. at least for me i have issues trying to stuff 3 inch pipes under the car.
  5. 1970_Z28_503
    1970_Z28_503 Veteran Member
    100
    8
    Apr 12, 2017
    Oregon
    I did that kit on mine with new headers and the Street pro mufflers and it was a royal pain in the A$$. Still hitting on the trans cross member now and then and fitting the tailpipes was much more difficult then I thought it would be when I ordered the kit.
  6. Gipper
    195
    Jun 29, 2002
    Rockwall TX
    I picked up a couple of swivel hangers from summit and mounted them on the crossflow muffler brackets. Worked great. I agree that the tailpipe design sux. I ended up cutting mine 2” after the final bend to clear the leaf springs and quarter panels.
    hubedobeedo likes this.
  7. hubedobeedo
    hubedobeedo 3rd times a charm
    207
    37
    Jul 18, 2013
    Huntertown,IN
    pypes 2.5 i used magnaflow stainless clamps and were the stainless two piece driveshaft loop is i mounted the hangers there with stainless fasteners(metal lock nuts ) i can remove bottom of loop without loosening the exhaust the hangers at back came with the kit i seemed to have lost that pic but its back by the end of tailpipe. i will retake and post
  8. Bandit723
    2,873
    385
    Oct 1, 2016
    Waupaca WI
    And there is no noise getting into the body of the car? Rubber is instrumental in isolating that...
