Quadrajet Divorced Choke Conversion??
Discussion in 'Engine Topic' started by kpb, Oct 12, 2019.
  1. kpb
    kpb New Member
    9
    Aug 12, 2019
    Does anyone know if you can get an electric conversion kit that is carb mounted and will allow you to run an aftermarket manifold and get away from the divorced choke all together? The only electric conversion kits I have found require you to still use the stock intake.
    Thanks!
  2. Gary S
    22,431
    759
    Some of the older aftermarket intakes from Weiand and Edelbrock have provision for a divorced choke. You might be able to find something newer that has it too, or locate an older version of the intake.
  3. jroach
    jroach Veteran Member
    1,292
    Apr 9, 2007
    petersburg MI
    you could always just treat it as a manual choke. set it and take it off with your foot. just would be all the way off or all the way on.
  4. kpb
    kpb New Member
    9
    Aug 12, 2019
    Thanks for the feedback guys, I'll probably just keep digging around and find a newer quadrajet I guess
  5. cadillac_al
    cadillac_al Veteran Member
    832
    85
    Apr 22, 2015
    Maine
    Yup, you can't convert a divorced choke carb to electric choke but you can convert it to a hand choke.
  6. 77 cruiser
    77 cruiser Veteran Member
    537
    24
    Nov 17, 2006
    Frostbite Falls MN
  7. TheFastForester
    TheFastForester Veteran Member Lifetime Gold Member
    1,472
    9
    Feb 9, 2008
    Broomfield, Colorado
  8. Lowend
    14,958
    440
    Mar 25, 1999
    San Jose, CA, USA
  9. cadillac_al
    832
    85
    Apr 22, 2015
    Maine
