Quarter Panel Inner Plug Area for a 74 Z28
Discussion in 'Body Restoration' started by 74Z28GC3, Jan 17, 2020.
  1. 74Z28GC3
    74Z28GC3 Veteran Member
    1,718
    57
    Sep 1, 2000
    North Pole, Alaska
    Is this the correct part to input in the inner lower quarter panel area? Also, is seam seamler required to be applied around that area? Thanks
  2. berg2695
    berg2695 Veteran Member
    295
    59
    Nov 13, 2011
    AUBURN, WA
    The plug on my '77 is metal but that one looks like it would work fine. No sealer is required. The factory put a slot at the bottom so water can drain.
  3. 74Z28GC3
    1,718
    57
    Sep 1, 2000
    North Pole, Alaska
    Ok, this one is metal with a gasket. Thanks
  4. bodymanbill
    bodymanbill Veteran Member
    1,389
    808
    Feb 1, 2007
    South Park Pa
    George I put a small amount of seamsealer on mine, just didn’t quite fit tight enough and was afraid it would fall out, but like berg2695 said leave the little notch at the bottom open.
  5. 74Z28GC3
    1,718
    57
    Sep 1, 2000
    North Pole, Alaska
    Bill, Ok, I thought I had the right parts and just wanted to make sure I had the correct parts. I will put some seam sealer around them and leave the little notch open. Thanks to you and berg2695 for your replies. George
