question about holley vac secondaries
Discussion in 'Engine Topic' started by cutty, May 13, 2012.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    as title says, i got to wondering today if my 4 barrels were opening, so i did the paper clip test on it and yup nothing,what im wondering is there a way to test the diaphragm?
    by the way its a holley 3310 carb
  2. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    Take it out and look for potential leaks (holes, tears, improperly fitted to mating surface, etc)... if you find none, try a lighter spring and try the paper clip thing again.
  3. cutty
    342
    Dec 12, 2008
    ontario canada
    found a hole near spring plate, got it changed now
  4. JasonZE
    JasonZE Veteran Member
    518
    Sep 11, 2009
    NewZealand
    what spring was in there? my new 3310 came with the heaviest spring they make so went to the purple spring (middle) and was way better as they open so much sooner I may try a lighter one still when i get time but happy so far.
  5. Damon
    Damon Veteran Member
    12,939
    21
    Nov 16, 2000
    Philly area
    The 3310 should come out of the box with the "plain" spring.
  6. cutty
    342
    Dec 12, 2008
    ontario canada
    mine had the black 1 in it, but as of last night now has a plain 1 in it,
  7. JasonZE
    518
    Sep 11, 2009
    NewZealand
    mine was a new 3310s and had black.
  8. cutty
    342
    Dec 12, 2008
    ontario canada
    i have it working now, just ordered a spring kit for it,gonna try some lighter springs and see,
  9. CorkyE
    10,453
    508
    Just keep going lighter on the spring until you get a stumble, then go back up one.
  10. z28cp
    z28cp Veteran Member
    345
    12
    Jan 16, 2009
    Bellevue, NE
    Curious... What is the 'paper clip test'?
