question for guys running the comp cam 280H
Discussion in 'Engine Topic' started by cutty, Apr 25, 2012.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    just wondering what kind of vacuum you guys are getting say, in a idle in park?
  2. cutty
    342
    Dec 12, 2008
    ontario canada
    forgot to add, its in a 355
  3. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    I have that cam, but it's hard to say because I have a reserve vacuum canister.
    Last I checked (when I was setting my idle mixture screws) it's ~12 in/hg but that may be irrelevant because of the canister.
    Mine's also a 350, Vortec heads, Weiand dual plane intake, Holley 650DP, Magnum 280 cam, plus I have Rhoads lifters.
    I took all the necessary precautions to make sure I had brakes at idle. :) Been there, done that. Don't want to do it again.
  4. zachisageek
    zachisageek Veteran Member
    335
    May 3, 2007
    Greenfield, WI
    The last time I checked I had something like 17" at idle.
  5. vlmohr
    vlmohr Veteran Member
    179
    Jul 8, 2010
    Bellevue, IA
    Vacuum canister shouldn't affect manifold vacuum. It's only a reservoir to store vacuum to run vacuum operated accessories while under a load if it's hooked up correct. My son's 383 has about 12 also.
  6. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,063
    Sep 22, 2007
    Blind Bay, B.C.
    Sounds as as if you may be ok, the 284H in mine is 9-10 in/hg, using a 4sp though. 12 sounds about right?
  7. AJ_72
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    I wouldn't think so either since it's really only hooked to the brake booster, but just wanted to be sure all info was given. ;)
  8. 5spd540
    12,390
    16
    Sep 19, 2009
    Guyton, GA
    I had a 360 that made almost no vac so the brakes sucked
  9. bitchin'71SS
    bitchin'71SS Veteran Member
    397
    Sep 10, 2009
    Poughkeepsie, NY
    I run that cam in my 383 no problems with vacuum ever, brake booster works fine. also putting one in my buddys 355 which is also a mild street 355, great street cam.
  10. cutty
    342
    Dec 12, 2008
    ontario canada
    i ask as i hooked a gauge up and getting only 10 inch's in park in a idle,ive check and rechecked timing and played with carb but 10 seems to be the highest i can get out of it
