Quick Question-Bullet Mirrors
Discussion in 'Body Restoration' started by 79camaro305, Jun 14, 2004.
  1. 79camaro305
    79camaro305 Veteran Member
    1,746
    Jul 8, 2001
    Hainesport, NJ USA
    I haven't looked at my car in a while, so I figured I would just ask here. What does one have to do to remove the Passengers bullet mirror? Is it held on by a screw? I would just go outside and ceck, but it's dark and stormy now. I figured I could have the answer by tommorrow with little work on my end.
    ~~Mr Lazy. [​IMG]
  2. gutted72
    gutted72 Veteran Member
    1,348
    173
    Mar 4, 2002
    Jennings, OK
    I believe it is held on with two nuts from the inside of the door. Or at least that is the way mine is.
  3. ericj205
    ericj205 Veteran Member
    1,758
    Jun 16, 1999
    Huntsville, AL USA
    its held on via one screw near the base of the mirror, the bracket below is held on by two screws into the door skin, there is a plastic grommet between the bracket and the door
    ericj205@nastyz28.com
    '71 RS/SS w/ vortec heads in progress
    '65 Chevelle Malibu 2dr Coupe
    "When I rev the engine I want people to think the world is coming to an end" -Homer Simpson
