QuickJack?
Discussion in 'The BS Topic' started by BonzoHansen, Aug 14, 2019.
  1. BonzoHansen
    19,390
    758
    Jun 1, 2005
    Scott from Hamilton, NJ
  2. Dave Nelson
    Dave Nelson Veteran Member
    4,297
    2,082
    Dec 19, 2003
    Vineland N.J USA
    Don't see using that jack vs. a good floor jack and quality jack stands. Using the Quick Jack you are limited to getting under the car from the front or rear not from the sides (not very useful on a trans swap), seems it would be in the way.
  3. camarochevy1970
    camarochevy1970 Veteran Member
    7,783
    51
    Jan 23, 2003
    Pittsburgh, PA
    not sure I trust one of those
  4. The Champ
    The Champ Veteran Member
    4,540
    547
    Sep 14, 2000
    MN
    That is an excellent price on that unit.
    I've been seriously thinking of getting one myself. These are extremely stable - I'd trust it just as much as the old jack stands...
    The lift height is 21.5 inches - and that's the tires being 21.5" in the air. Great for detailing rims on the car while sitting on a stool. Much easier to get underneath the car for us old farts for changing oil or other routine issues.
    As far as a tranny swap goes - the added height would make working underneath easier. There's enough room to get the tranny in from the front or back without too much trouble.
    And it's pretty easy to transport if you need to use it at a different location, too.
  5. Knuckle Dragger
    14,731
    1,284
    Nov 2, 2002
    Waddell AZ
    It doesn't seem much easier/faster than jack and jack stands to me. No way I'd get under it. Looks like a huge discount.
    carr911 likes this.
  6. The Champ
    4,540
    547
    Sep 14, 2000
    MN
    Dave
    You get under hoists everyday you're at work. These lock in a similar manner once the hydraulics raise it up.
  7. Knuckle Dragger
    14,731
    1,284
    Nov 2, 2002
    Waddell AZ
    That's like saying a Chevette is just like a Corvette.
    This is what I get under everyday. https://mohawklifts.com/automotive-lifts/2-post-lifts/lmf-12-tp-16/
    Notice some difference in the thickness of the steal, the locks and the hydraulic rams? Not even close to what Scott posted.
    Dave Nelson likes this.
  8. The Champ
    4,540
    547
    Sep 14, 2000
    MN
    I understand that a 16,000 - 18,000 pound lift is built with much heavier steel and much bigger hydraulic rams, but the QuickJack is a 7,000 pound lift designed for much lighter vehicles.
    You're not supposed to put a fully loaded 1 Ton plumbers van on a 7,000 pound lift, are you??? ;)
  9. Knuckle Dragger
    14,731
    1,284
    Nov 2, 2002
    Waddell AZ
    Man you just can't get over it when someone disagrees can you?:) Comparing that lift to a good lift is just plain silly. It's no where near as strong or stable. The lock mechanism is a joke compared to what I use daily. If you want to crawl your azz under that thing by all means buy one, enjoy it, brag about it, but it's not anywhere close to what I use everyday and it's ridiculous to say they are.
    The Mohawk 7000lbs lift: https://mohawklifts.com/automotive-lifts/2-post-lifts/a7/
    Look at the pictures, pay attention to the steel thickness, look at the locking mechanism and tell me with a straight face they are the same thing. You'll make a fool out of yourself trying but I'm starting to think you'll disagree just to be disagreeable :eek:
    Shizzle likes this.
  10. Lowend
    14,968
    445
    Mar 25, 1999
    San Jose, CA, USA
    We looked at these for work a while back. They don’t appear to be badly built, But in my opinion I don’t really lift the car high enough to be useful. You can get a scissor lift for under $1000, a couple of two by sixes later and you’ve got a fully functional lift
