R134 Can Tap
Discussion in 'Tips 'n' Tricks Topic' started by badazz81z28, Apr 23, 2019.
  1. badazz81z28
    16,165
    377
    Las Vegas, NV
    Is there a tap out there that has a valve? The tap I have is open to free air no matter what position. This means when I disconnect a can I have to purge it every time versus if there was a valve at the can I wouldn’t have to.
  2. Twisted_Metal
    26,709
    816
  3. badazz81z28
    16,165
    377
    Las Vegas, NV
    I’m actually looking for one that has a valve that seals when fully opened and closed. Seems the valve I have only seals the can from dispensing with the piercing needle extended. That means when I swap the can, the system up to the valve on the charging hose is open.
