Radio Noise Help Needed.
Discussion in 'Car Audio, Electronics & Security' started by slayer021175666, Aug 25, 2016.
  1. slayer021175666
    slayer021175666 Veteran Member
    1,224
    60
    Feb 29, 2016
    Idaho
    I wondered that, myself so I disconnect all grounds including the antenna and tested the grounds for the radio's ground wire and at the bracket that holds up the rear casing of the radio with a test light. I put the test light clip on the positive power source and touched the test light tip to the bracket and the light came on. Then, I touched the tip to the screw I am using for the radio's ground wire and it came on again. Since the antenna wire itself can ground it, I left the casing bracket and the ground wire disconnected and plugged in the antenna cable. The radio lit up and began to play. So, as near as I can tell, all 3 grounds are working properly.
    This really sucks but, like all other problems, I AM GOING TO BEAT IT! Somehow, anyway! :)
  2. wnmech
    wnmech Veteran Member
    970
    116
    Jul 20, 2014
    grand prairie tx.
    You could be right about the increase of rpm changing the noise but stranger things have happened. When you do find the problem dont forget to tell us the cure.
  3. slayer021175666
    1,224
    60
    Feb 29, 2016
    Idaho
    Sure thing, brother. I'm going out soon to try out the suggestions.
  4. perkalator
    perkalator Veteran Member
    1,025
    90
    Aug 27, 2014
    kennewick wa
    Is your radio wired direct to battery or key on circuit. Make sure your not tapped into the ignition circuit.
  5. slayer021175666
    1,224
    60
    Feb 29, 2016
    Idaho
    Its wired to the fuse block. I'm gonna try putting it on a different terminal or run straight to the battery. I'm just gonna throw every suggestion at it and see what sticks.
  6. slayer021175666
    1,224
    60
    Feb 29, 2016
    Idaho
    Well, nothing works. It has to be something with the distributor, I think. I unplugged the alternator. Made sure the blower is turned off, too. Only thing that is spinning is the crank and the distributor. If it was a problem with the radio itself, it would buzz with the engine on or off. Only buzzes with engine on.
  7. giggity
    giggity Veteran Member
    1,037
    128
    Mar 18, 2013
    Pearland, texas
    try a different head unit. Could be bad radio.
  8. flint9
    flint9 Member
    96
    9
    Jun 6, 2016
    st louis mo
    try unplugging tach.
  9. slayer021175666
    1,224
    60
    Feb 29, 2016
    Idaho
    Tried it, yesterday. No avail but, thank you.
  10. RLL Z-28
    RLL Z-28 Veteran Member
    188
    Jul 2, 2013
    Chattanooga,Tennessee
    Is your ground from the cowl to the hood missing? It isn't a wire but a a flat horseshoe shaped piece of metal with jagged teeth on the end that makes contact with the hood. They are for radio noise and should be mounted on the cowl in front of where the antenna connects to the windshield. If you had a fender mounted antenna it would be mounted on the cowl nearest to the fender where the antenna is. Most of the time they are missing you can get them off ebay for about $12.00 just something else to check.
