Rear axle bumper
Discussion in 'Camaros Wanted' started by arm2004, Oct 10, 2018.
  1. arm2004
    arm2004 Member
    89
    10
    May 5, 2017
    S.E. Ohio
    need one rear axle bumper/ rubber avle stop. this sits on outside rear frame rail at the curve and has a triangle bolt pattern. From what i found out 1970-74 are the same and either side will work.
  2. BillyDean7173
    BillyDean7173 Veteran Member
    1,693
    360
    May 21, 2014
    Hutto, TX
  3. arm2004
    arm2004 Member
    89
    10
    May 5, 2017
    S.E. Ohio
    It is for a 1970 the rubber does not bolt in beleave it is the first design. Thanks for the info i could not find any info on it.
    BillyDean7173 likes this.
