Rear Disc Brake Conversion
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Brizio, Sep 15, 2019.
  1. Brizio
    Brizio Member
    39
    Mar 27, 2012
    Portland, OR
    I have a stock '79 Z28, and I would like to swap the rear drums with disk. What conversion kit do you suggest?
    Thanks!
  2. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,016
    149
    Dec 19, 2008
    so many options. Jegs or summit for kits starting at $799
  3. Twisted_Metal
    26,944
    925
    What is the use for the car?
    What size wheels?
    If you are planning autocross competition... Go for it.
    Street driven with 15" wheels... Probably not worth the expense for the rotor size limitation.
    A 79-81 WS6 Trans Am could be a bolt-in donor but those rears are getting harder to find.
  4. CorkyE
    10,266
    430
    I used these guys, IIRC got the kit through Summit because of a discount. I've been well pleased with how they work, just watch the video, especially on bleeding calipers and adjusting e-brake. You'll need the staggered shock kit for a Z-28. https://www.getdiscbrakes.com/afxrd07
  5. Twisted_Metal
    26,944
    925
    That’s a pretty decent price!
    Just add brake pads and some wrenching.
    Did you also need an adjustable proportioning valve to use that kit?
  6. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,368
    80
    Feb 2, 2008
    SF
    Call tobyn at kore 3
  7. CorkyE
    10,266
    430
    Brake pads were included in my kit. I bought a disc/disc prop valve from the same supplier. I've considered changing to an adjustable but the system works fine as is. I think this is same brake setup as older Cadillac Escalade.
  8. ruthlessz28
    ruthlessz28 Member
    81
    15
    May 9, 2009
    crystal lake, il
    on summits web site they have a kit im considering for under $400 complete with staggered shocks and under $300 with nonstaggered jegs has the same kit
  9. Jon balch
    Jon balch Veteran Member Gold Member
    233
    67
    Mar 29, 2017
    Upstate NY
    I just installed Willwood rear brakes on my 1970. Also installed new axles, Master cylinder, parking brake cables, Caltracs , and Moser differential cover. brakes1.jpg brakes2.jpg brakes3.jpg
    mrfleet12, dave@ztech and cadillac_al like this.
  10. dcozzi
    dcozzi Veteran Member
    2,955
    335
    May 1, 2002
    Phoenix, AZ
    I have Wilwood 4 pistons in the rear too. Good thing you have a prop valve since the pad area is pretty large. May have to dial it back a bit since they only do 30-40% of the work.
