Rear Disc Brake Conversion
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Brizio, Sep 15, 2019.
  1. Z28 Mark
    Z28 Mark Veteran Member
    215
    Feb 14, 2001
    San Jose, CA.
    I have been wanting to put disc brakes on my "73 Z28 and now have the money to do it. I was wanting to keep the 15" rims and the "Right Stuff" does have a kit for this- Does the slimier kit from Summit compare to this? Any other good deals out there?
  2. CorkyE
    10,402
    484
    I did some checking around, seems like the lower price kits that use GM parts with manufactured brackets, cables, hoses, etc, are all comparable in price. The break will be in taxes, shipping, or if someone is offering a discount. Be aware that the lowest cost kits do not include parking brakes. I did not opt for slotted disc, braided hoses, or powder coated calipers either. Painted mine with hi temp paint, no problems.
  3. Patrick1971Ls6
    Patrick1971Ls6 New Member
    Oct 23, 2014
    Austin
    I just did a four wheel modern disc brake set up on my car from right stuff, powder coated calipers single piston, slotted 11.5 rotors parking brake worked out well. Under 1,000 bucks.
  4. Zspoiler
    Zspoiler Veteran Member
    3,272
    266
    May 6, 2012
    Federal Way, Washington
    I use a complete Baer 4 wheel disc brake kit 13" front ,12" back. An 84 Corvette master cylinder and a 1979-81 Firebird WS-6 proportioning valve. But on the lower end I would try to find a WS-6 Firebird setup.It would probably be a lot less money .And cheaper as well. Its something Chevrolet should of offered.
    hubedobeedo likes this.
  5. mrfleet12
    mrfleet12 Veteran Member
    326
    91
    Aug 8, 2014
    West of Chicago IL
    Curious about the Corvette MC, was that a direct bolt on and what advantage is there for that VS one from a WS6 like the prop valve?
    Thanks
    Fleet
  6. Fbird
    4,062
    659
    Feb 12, 2011
    atlanta, ga
    Now that everybody and their brother are making the rear "screw" calipers these kits are dirt cheap bolt on everything included in the sub $500 market.....IF you like that type of PITA e-brake set-up that GM did 40 yrs ago. I personally do NOT (my bird is GM wheel disc) I would gladly convert the rear to SOMETHING with an internal drum type e-brake....when i get that far down on my list... :(
    cadillac_al likes this.
  7. CorkyE
    10,402
    484
    I would much rather remember to occasionally engage the e-brake while in reverse to keep adjustment, rather the complexity of another brake system.
  8. GDSmith
    GDSmith Veteran Member
    140
    26
    Aug 4, 2012
    Glen Ellyn, IL
    cadillac_al, mrfleet12 and dave@ztech like this.
  9. czizza
    czizza Veteran Member
    1,029
    68
    Jan 8, 2004
    N. Massapequa, NY, USA
  10. Fbird
    4,062
    659
    Feb 12, 2011
    atlanta, ga
    never seen that one!...yay....but using a Citation caliper...WTF.....BUT i bet it would be an EASY fix to take that plate and mod it for say...S-10 or C-5 calipers!!!! solves that entire 2wd drive 4 wd blazer mess for the backing plates??
