Rear Disc Brake Conversion
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Brizio, Sep 15, 2019.
  1. Fbird
    3,942
    615
    Feb 12, 2011
    atlanta, ga
    you cant get much more complex than the rachet screw inside the piston assembly of a stationary caliper....
    1 hydraulic caliper , 1 cable drum ...completely independent of each other.
    again its all about choices, what fits, and ultimately what you want. I am appreciative of the information compiled within this blog as there are always many different resources.
  2. cadillac_al
    cadillac_al Veteran Member
    834
    85
    Apr 22, 2015
    Maine
    I gave up bad mouthing Cadillac calipers a while ago. I figure if someone wants to go this route they should google it first, to at least know about the down side going in. I have been rebuilding them for the last 25 years. The theory looks good on paper but the park brake holding power is very weak. Drum brakes will drag tires like an emergency brake. I do like the looks of that S10 setup that was linked on the previous page.
  3. Wayne Trafford
    Wayne Trafford New Member
    Oct 9, 2005
    Shelburne Ontario Canada
    I just bought a conversion kit for my 1979 Z28 from Ecklers Camaro. It came with everything including parking brake cables and it only cost $400.99.
  4. Brizio
    Brizio Member
    39
    Mar 27, 2012
    Portland, OR
    I'm planning to autocross and other races.
  5. Brizio
    Brizio Member
    39
    Mar 27, 2012
    Portland, OR
    That's a great price!
  6. Brizio
    Brizio Member
    39
    Mar 27, 2012
    Portland, OR
    Do you have a link? I cannot find it
  7. Brizio
    Brizio Member
    39
    Mar 27, 2012
    Portland, OR
    I will check them out! Thanks!
  8. badazz81z28
    16,675
    462
    Las Vegas, NV
    There’s a wS6 rear disc in the swap meet
  9. badazz81z28
    16,675
    462
    Las Vegas, NV
  10. ruthlessz28
    ruthlessz28 Member
    81
    15
    May 9, 2009
    crystal lake, il
    not a link I called and talked directly to a tech specialist. I think I have the part numbers in my toolbox, I'll check Monday and post them if I have them.
