Rear Disc Brakes
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Plute1970, Feb 10, 2019.
  1. badazz81z28
    17,406
    605
    Alabama
    Going from drums to disc does call for the proper booster and MC to include the proper proportioning valve.
    You can snag it all from a WS6 equipped 77-81 trans am
    Rick Figus likes this.
  2. Rick Figus
    Rick Figus New Member
    17
    Feb 5, 2019
    Oak Forest, Illinois
    Thanks I got in contact with pirate Jack's and Asheville North Carolina they seem be very knowledgeable.
  3. 1971CamaroGuy
    3,775
    172
    Oct 31, 2004
    I had a decent drum set-up on my 71, but with having C5 size slotted rotors on front and 18" wheels you can see through, I wanted to match the back. Didn't want a drum peeking through the back.
    I got a brake retrofit kit for the rear from inline tube on eBay and it was less than $400. My only issue was the length of the parking brake cables were to short in my opinion so I spent another $150 having a longer set made
  4. 75Maro
    75Maro Veteran Member
    440
    28
    Mar 31, 2008
    Dallas,Tx
    Who/where did you get the longer set made
  5. czizza
    czizza Veteran Member
    1,062
    80
    Jan 8, 2004
    N. Massapequa, NY, USA
  6. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,025
    149
    Dec 19, 2008
    SO TRUE!!!!!!!
    cadillac_al and 70ZED like this.
  7. Skip Fix
    Skip Fix Veteran Member
    2,193
    24
    Mar 21, 2007
    Katy,Texas
    WS6 rear brake brackets are NOT welded to rear end they bolt the same way drum backing plates or other kits -4 bolts on the axle flange.
    Granted the E brake ratchet is a pain and often freezes and lifetime warranty rebuilt calipers are your friend! The can be made to work and do work better than the rear drums on these cars-My 78 had drums when I first starting autocrossing then swapped the disc on and a much more predictable balanced braking system especially with the road race slicks.
  8. Hogg jr
    Hogg jr New Member
    Nov 22, 2016
    Any one know where to get cross drilled rotors \ slotted for the s10 rear conversion
  9. CorkyE
    10,537
    549
    Rock Auto carries several levels of disc, at a reasonable price. IMHO, your wasting money with cross drilled & slotted on rear, just plain rotors will work fine unless you're doing some serious auto crossing.
    Hogg jr likes this.
  10. BonzoHansen
    19,641
    903
    Jun 1, 2005
    Scott from Hamilton, NJ
    AutoX doesn't impact brakes enough to ever need it. open track does.
