Rear end Gear swap questions
Discussion in 'Transmission & Driveline Topics' started by Kixxis, Apr 11, 2019.
  1. Kixxis
    Kixxis New Member
    20
    Jun 6, 2016
    Afton, NY
    Hello everybody!
    I have a '79 RS that is mostly bone stock. From what I believe the rear end is original with a limited slip (I believe, I didn't look it up) 3.73.
    Now I'm looking to lower my rpms and gain highway speed drivability. I have an '83 K10 with a (again haven't looked at it but have spun and measured it) measured 2.71ish. The big question is will that gear pack fit in my '79 with minimal issues? I have the muncie 4 speed and 60 mph at the moment is about 3100 rpms. Any input is appreciated. Thank you!
  2. camaro71/holland
    1,221
    79
    Aug 27, 2003
    The Netherlands
    3100 equals 3.9 to 4.11 with 1:1 trans end ratio depending on the tire size. Recheck your gear ratio..
  3. Kixxis
    Kixxis New Member
    20
    Jun 6, 2016
    Afton, NY
    Okay I guess I will have to tear into it when I get some time. Is a swap possible between the two?
  4. tom3
    tom3 Veteran Member
    11,938
    330
    Aug 1, 1999
    ohio
    Any junk yards around? Pick a part etc? Be a whole lot simpler to do the whole axle swap and keep yours intact, might be worth some serious money too. About any V8 automatic would have a 3:08 or 2:73 gear and lots of posi gears up there in your area I'd think. I'd try that route first.
  5. big gear head
    big gear head Veteran Member
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    A gear in the 2.73 range is going to make life hard on your clutch. I would not recommend it at all.
    As for your original question, yes, the K10 gears and differential will fit in the Camaro rear end, but a complete rear end swap from another Camaro or Firebird would be MUCH easier.
    I'm never going to get use to all of the people who have 3.73 gears that want a 3.08 and all of the people who have 3.08 gears that want a 3.73. I guess that is what keeps the gear manufacturers in business.
    Dave Nelson likes this.
  6. Gary S
    22,485
    778
    Before you do anything else, determine what gear ratio you currently have in the car. In 1979, only the Z28 with manual tranny could have a 3.73 rear end. You say you have an RS. The RS couldn't get anything deeper than 3.08, and depending on engine and tranny, it could even be a 2.56 or 2.41.
  7. DesmoEd
    DesmoEd Veteran Member
    1,138
    Sep 9, 2009
    Frisco, TX
    I'd also determine what 4 speed you have as 1974 was the last year GM used a Muncie in any car. The later Borg Warner tranny's had a few different gear sets depending on year.
  8. Kixxis
    Kixxis New Member
    20
    Jun 6, 2016
    Afton, NY
    -I do have some pick n pulls around here but everyone act like vultures when they show up at the yard, understandably.
    -If the smaller gears would be not so good for the clutch, is there another way of getting better highway drivability besides a different tranny?
    -I will look into the ratio this weekend if I get some time and just spin it and get a quick measure.
    -When I had the clutch replaced they said it was a muncie but it's probably a Saginaw but I will also double check to be sure.
    Thank you all for your replies!
  9. 70-camaro
    70-camaro Veteran Member
    2,313
    403
    Mar 25, 2010
    marietta ohio
    I would go for a 3.42 gear
  10. tom3
    tom3 Veteran Member
    11,938
    330
    Aug 1, 1999
    ohio
    A muncie would have an aluminum case, Saginaw is cast iron, a magnet will tell. The Saginaw might have a real low ratio first gear that would work well with a taller rear gear. Ultimate solution would be a Tremec 5 or 6 speed box.
