Rear end gears
Discussion in '1978 - 1981 Specific' started by Clifford Barfield, Nov 25, 2019.
  1. Clifford Barfield
    Clifford Barfield New Member
    Nov 25, 2019
    I have a 1979 Camaro RS. It has 2:41 rear end gears. I kept the original 305 motor but beefed it up with a mild cam, Vortec heads, 650 carburetor and dual exhaust. I swapped the T350 for a 700R4. Now I wan to change the rear end gears. I am deciding between the 3:08 and the 3:42's. I have the original rims (14") and tire height is 25".
    I like the power of the 3:42 gears but don't want to lose my ability to cruise on the highway at 80. Any ideas?
  2. CorkyE
    10,435
    504
    The 3.42 gear will work fine with your 700-R4 transmission. I'm running 3.73 gears with a much taller tire. You're probably lugging that engine real hard with those 2.41 gears.
    BTW, welcome to NastyZ.
    buick skylark likes this.
  3. CDesperado
    3,590
    79
    Oct 1, 2004
    Dallas Texas
    I went with 3.73 gears and a 700R4 tranny. Im pretty happy with the combo so far.
  4. ULTM8Z
    ULTM8Z Veteran Member
    9,209
    365
    May 19, 2000
    Los Angeles
    With 3.42 and th700r4, I'm only doing about 2400 rpm at 70 mph.
  5. Twisted_Metal
    27,143
    1,040
    3.42 gears with a 700r4 (0.70 OD) gives you a final gear ratio of 2.39.
    Your highway cruise RPM will be virtually identical to the 2.41 gears you have now with your TH350.
    A 3.73 ratio would also be a good choice as your highway RPM would only go up about 10%.
  6. CorkyE
    10,435
    504
    Anyone else notice this is OP's first and only post, and last activity is post date. We've had a couple of these lately.
