Rear End Noise when Spinning by Hand
Discussion in 'Transmission & Driveline Topics' started by Smiles 79, Aug 23, 2019.
  1. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Hey all,
    So I set up an Auburn posi with 3.42s from USA Standard Gear in blmy 8.5". When I spin the axle by hand, I get a bit of a clunking noise. Backlash is in spec, the pattern looked good, and everything is torqued down. Any idea what this might be?
  2. flht99b
    flht99b Veteran Member
    253
    41
    Nov 28, 2014
    Knoxville, TN
    Do you have oil in it yet? Sounds dry.
  3. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    I've got 2 qts plus some limited slip additive in it.
  4. COPO
    17,722
    691
    Go do 5 figure 8's in one direction in an empty parking lot and do 5 more going the other way in a figure 8. That will mix the additive for the posi clutches then report back.
  5. big gear head
    big gear head Veteran Member
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    NO! DO NOT DRIVE IT LIKE THIS! It has nothing to do with oil additive, clutches or anything like that.
    Is the pinion bearing preload set correctly? Something is not right.
    budro6968 likes this.
  6. badazz81z28
    16,699
    463
    Las Vegas, NV
    Yeah, thats exactly how a used rearend I bought years ago sounded like. The crush sleeve was not crushed! lol. You could turn the pinion backwards and it would spin out of the gear.
  7. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Thanks for the responses evrrever. I didn't even have the housing bolted to the leaf springs so I yanked it back out of the car to inspect it tomorrow.
    Could incorrect carrier bearing preload cause this? When I set the diff up I had good backlash, good pinion preload, and a good pattern. I measured the shims and adjusted to get my backlash, but I didn't have to hammer them in.
  8. big gear head
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    If you can pull the differential out by hand then it's not tight enough.
  9. camaro71/holland
    1,222
    80
    Aug 27, 2003
    The Netherlands
    There is no pre load on the pinion bearings either, it spins way too easily...
    Did you check this with a torque o meter? Should read 20-25 INCH pound of force with new pinion bearings.
  10. camaro71/holland
    1,222
    80
    Aug 27, 2003
    The Netherlands
    And not needing to tap in the carrier bearings means these are way too loose too...
