Rear End Noise when Spinning by Hand
Discussion in 'Transmission & Driveline Topics' started by Smiles 79, Aug 23, 2019.
  1. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    I'll have to go check that. It won't be much.
  2. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Alright, got another pattern. I've attached the pictures, I'm Lookshaving kind of a hard time reading it. Any help is greatly appreciated!
  3. big gear head
    big gear head Veteran Member
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    Drive side doesn't look too bad, but the coast side is not readable. Did you use an axle to turn everything at least 5 or 6 FULL TURNS in both directions? Also, you didn't answer post number 50 yet.
  4. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Yes I did, 6 full turns using the axle. As for spinning the pinion, it doesn't free wheel by any means. Maybe half of a turn? I'm not positive and I'm not by the car right now.
  5. big gear head
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    Something is wrong with the coast side. The pattern is way off the heel end. The drive side looks like the pinion is not deep enough.
  6. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Hey all, thanks for all the help with this.
    I shimmed the pinion all the way up to almost .060" and the pattern didn't seem to change much. That seemed like a pretty large amount of shims, so I started going the opposite way from the stock shim, and the pattern looks better I think. Thoughts?
  7. big gear head
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    The coast side looks much better, but the drive side doesn't look deep enough. How does it sound now when you turn it? Did that noise go away?
  8. camaro71/holland
    1,222
    80
    Aug 27, 2003
    The Netherlands
    Just to rule everything out..... the R&P were a set? You didn't mix two different sets, did you?
  9. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Here is another video. Pinion preload is about 19 in lb, backlash is .007" and you saw the pattern I just posted. I'm using setup bearings if that makes a difference (the very first video was not).
    Some of the noise is my jackstands moving around while I was spinning the axle
  10. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Nope, ring and pinion were a set.
