Rear End Noise when Spinning by Hand
Discussion in 'Transmission & Driveline Topics' started by Smiles 79, Aug 23, 2019.
  1. big gear head
    big gear head Veteran Member
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    I'm having a hard time figuring out if the noise is from the gears or the jack stands. Is it still the same as it was before or is it better?
  2. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    The few spins at the end I think the jack stands stayed still. The noise sounds better, less clunky.
  3. big gear head
    6,182
    84
    Jul 30, 2001
    Central City, Ky.
    OK, this one has me stumped. I don't know what else to tell you. It's hard to figure out something like this through pictures and videos.
  4. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    I understand, I appreciate all the hp! Now that I've got the pattern in a good spot, I may just run it.
  5. badazz81z28
    16,698
    463
    Las Vegas, NV
    Before you run it, are you replacing the wheel bearings?
  6. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Yup, wheel bearings have been replaced.
  7. Smiles 79
    Smiles 79 Member
    39
    Jun 6, 2018
    Northwest Missouri
    Well I've got about 160 miles on the new rear end. It does make some noise, but I attribute that to the cheap gears. Seems to be getting better with the break in.
