rear end ???'s
Discussion in 'Transmission & Driveline Topics' started by InitialD, May 12, 2007.
  1. InitialD
    InitialD Veteran Member
    981
    Jun 18, 2001
    Wichita, Ks
    I heard somewhere here a few years back that the rear end gear on old trucks and suburban 10 bolts can be used in our cars. Is this true? they are the 8.5, just longer axles, right? What were the factory gears used in a 77 2wd c/k10 suburban? I'm considering getting the ring and pinion off of a parts truck I have access to, and I'm wanting to know if they'll work, and what else I can use...
  2. ric70ss
    ric70ss Veteran Member
    364
    Sep 1, 2005
    San Antonio, TX ,USA
    yes as long as it is a 10bolt 8.5
    should be 3.08 ,3.42,3.73 the last 2 would b found on towing package or 6 cyl engines if i remember right but check the ring gear the number of teeth should b stamp on it
  3. big gear head
    big gear head Veteran Member
    6,115
    60
    Jul 30, 2001
    Central City, Ky.
    All 8.5 ring & pinion gears will swap, even the ones in the front of 4X4 trucks. If you have an Impala or Caprice with the speed sensor on the pinion shaft then you will need a gear set that is made for this sensor.
