Rear End score! Now how to proceed...
Discussion in 'Transmission & Driveline Topics' started by JordonRS355, Apr 23, 2019.
  1. JordonRS355
    JordonRS355 Member
    78
    Jul 31, 2015
    Eastern Kentucky
    So today I lucked out and got the next piece to the puzzle. My buddy from work has a friend that owns a junkyard and he hooked me up with a Ford 9 inch reared pulled straight from a 79 Bronco. FOR 50 BUCKS!
    My plans are to clean this sucker up, take some measurements and get the housing in at the right length and setting. From there I’m going to try to find some correct length 31 or higher spline axles for a 9 inch with the GM 5x4.75 bolt pattern so I can run my same wheels. One question I have for anyone else whose done this is what axles did you use? I seen some axles on Speedway Motors that “cut to fit.” Basically the whole axle shaft starting at about half way has splines and I guess you cut at the correct length you need. Any insight on as to whether this is worth a shot? Or even better suggestions are welcome.
  2. Shizzle
    Shizzle Veteran Member
    2,532
    522
    Aug 1, 2012
    oak lawn, illinois
  3. big gear head
    big gear head Veteran Member
    6,187
    86
    Jul 30, 2001
    Central City, Ky.
    Once the housing is narrowed and ready to use you can take measurements and call Moser Engineering. They will make the axles to fit with any bolt pattern you want.
  4. Rich Schmidt
    Rich Schmidt Veteran Member
    4,278
    38
    Mar 27, 2010
    Denville NJ
    Also buy new housing ends or at least make sure yours are the Ford "big bearing" design. It will be easier to find brakes and fit in large axles.
  5. Scott51
    Scott51 Veteran Member
    625
    73
    Jan 2, 2012
    New Zealand
