Rear frame rail....
Discussion in 'Body Restoration' started by bigdav160, Apr 19, 2015.
  1. bigdav160
    bigdav160 Veteran Member
    592
    Jan 11, 2006
    Klein Texas
    ...is finally out of there.
    Not terribly difficult it's just hard to find a few hour block of time.
    Now I need to clean up those leftover spot weld dimples and test fit the new rail.
  2. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    more info please
    WE NEED MORE DATA:)
    I'm going to have to tackle this problem in the near future. Any more info and PICTURES would be greatly appreciated.
    Thanks
  3. bigdav160
    592
    Jan 11, 2006
    Klein Texas
    Phat, I removed most of the rail leaving just the spot welded flange.
    This was important around the shock tower because I couldn't identify the welds from the outside. I still don't see how the factory spot welded that part of the rail.
    There are quite a few spot welds at the spring perch/ torque box area. With most of the rail cut away I could look inside and outside to identify.
  4. phat80
    1,021
    13
    Jan 4, 2013
    Victoria BC
    more data please
    I'm closing in on this frame rail repair ( forward section). It looks like I may need some of the floor in that area too.
    It's really difficult to see just how things are put together. Where did you find your frame rail? I tried AMD, no luck.
    EDIT: Just looked at your pix again. Mine is rotted right at the front, the part is on your hoist, and the heavier steel around it.
    Thanks
