Rear seat back bolt size?
Discussion in 'Interior Restoration' started by AllensaurusRex, Sep 9, 2019.
  1. AllensaurusRex
    AllensaurusRex Veteran Member
    535
    31
    May 22, 2013
    Murfreesboro TN
    Good morning!
    I've done a good bit of research, but I can't seem to find the bolt size for the upper portion of the rear seats? I'm looking specifically for the 2 bolts that hold the upper section of the rear seats (not the buckets) to the car.
    Thanks!
    -Allen
  2. grzewnicki
    3,213
    76
    Dec 9, 2009
    Gordon from Jacksonville Fl
    1/4-20, about 1 inch long, stock ones have a large retained washer on them. But you could use a fender washer, probably not an easy bolt to find, unless you find someone parting out a camaro, their hidden so hardware store bolts wil work.
  3. INSPECTOR57
    INSPECTOR57 Veteran Member Lifetime Gold Member
    465
    10
    Sep 14, 2007
    Stillwater, Oklahoma 74075
    Here's some pics - this is from an '80 model, same size as the ones on my '73.
    The sheetmetal screw has a 7/16 head & is 7/8" long with a 1.75" diameter captured washer that is 1/16" thick.
    Gary
