Rear spoiler on dragcar
Discussion in 'Competition Camaros' started by 70RS/SS396, Dec 31, 2011.
  1. 70RS/SS396
    70RS/SS396 Veteran Member
    557
    Jul 18, 2005
    Europe
    Hello
    I have i dragrace camaro 71. And now I have a new motor in it. Expect to run 180-190 mph.
    I dont have any rearspoiler at the moment....but I think I need one now with the new motor in the car.....
    How about the big original rear (3 piece) spoiler.....does it generate good downforce?
    Thanks
  2. mrdragster1970
    What tire are you running??
    You might not need down force, but more likely you need to stop it from lifting.
    I have always been told our cars start to wrap around at ~140 mph.
    I run 160 with the small 1 piece stock spoiler on a 10" tire.
    I put it on when I hit 140's and never had an issue even with a tiny tire.
    Now if you are trying to do 190 on a small tire, then you will probably need some down force.
    Personally I would want an adjustable set up so you don't have an anchor dragging back there that you don't need.
    I can see the stock 3 piece being a pretty big drag, that you are stuck with, needed or not.
    In my class there are a bunch of guys running 200+ with a small modern Pro-Stock set up.
    The days of the giant wings are over, they are not needed anymore.
    You want the minimum drag, the air moved away from the body, and the least amount of down force that is required.
  3. 70RS/SS396
    557
    Jul 18, 2005
    Europe
    I run either 33x14,5-15 or 32x14-15 tires. Car weight 2288 lbs on the startline with me in it, and a smallblock motor. But now im going to drive a bigblock in it.
  4. mrdragster1970
    What kind of engine combo is it?? 190 is frigging fast,
    and takes decent power, even in a light car like yours.
    With the added weight, it's probably going to take ~1300 HP plus to get in the 190 mph area??
    I know my car is heavier then yours, but it took almost 1500 HP to get mine in the 190's.
    I'm actually working on a 1600 hp+ motor now to try and get the car back over 200 mph if I can lose some weight also??
  5. muscl car
    a member here ....brant "mean sbc" who runs XDR 275 in PSCA and class champion fore 2011 has gone 7.910/188.41mph with this set up
  6. strstk71
    strstk71 Veteran Member
    536
    Aug 12, 2005
    Surrey BC Canada
    is that the crank drivin supercharger on that thing? or a big ass turbo???
  7. muscl car
    1 very big Precision turbo PT 114 mm turbo feeding a 555bbc !!!:)
  8. wild84
    wild84 Veteran Member
    380
    Jun 2, 2009
    Las Vegas, nv
    It's also not a factory spoiler, it is adjustable, and he's doin what Mrdragster was talkin about of goin fast on a small tire.
    It's also been down the track without the spoiler on it :crazy:
    Edit, it's a 118mm and been 7.6x 192+....
    ps. I think Brant has a fan club!
  9. muscl car
    here's another view of brants rear spoiler ....
  10. muscl car
    al jimenez went 7.24/200mph with this set up and same rear wing as brants
