Rear subframe repair or replacement
Discussion in 'Body Restoration' started by Tonion96, Feb 15, 2020.
  1. Tonion96
    Tonion96 New Member
    Feb 15, 2020
    Just bought a 1977 camaro rear pass side subframe right where in turns down has a hole rest of the subframe is clean I see that they sell replacement rails is there any write up on doing it I hear it's a hell of a job to do, I want to do it as right as possible and make it look as original as possible
  2. x77-69z28
    x77-69z28 Veteran Member
    355
    30
    Feb 5, 2010
    long island, new york
    I had the same rust on my 70. My body man did the repair perfectly. We drilled out the spotwelds, stepped the end down to slide inside the original rail and stitch welded it. Drilled where the orig spotwelds were, and plug welded them. Invisible repair!
    hubedobeedo likes this.
  3. 70lt1z28
    3,518
    711
    Oct 3, 1999
    Beavercreek, Ohio, USA
  4. Canadian Barton
    Canadian Barton Veteran Member
    251
    63
    Jul 20, 2015
    Alberta
    I didn't even know I needed one of those until now. lol
