Recently bought an 81 Z28. No blinkers. No dimmer.
Discussion in 'Electrical Systems' started by 54baker, Aug 25, 2017.
  1. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    Looks like the car has an earlier model year tilt steering column. The 81 should have the summer on the column. This column doesn't have it. Also, the blinkers don't work... where do I start? Anyone have a link to a wiring diagram I can print? Maybe a blinker module bad? Guessing that when the p.o. put in the column, he never hooked up the blinker wiring or put in a floor dimmer....obviously. Thank you
  2. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    Fyi, I tried looking at the stickies but most diagrams were photobucket and I refuse to pay for a subscription to them....
  3. Twisted_Metal
    27,144
    1,040
    The dimmer should be on the floor for an 81.
    The signal light flasher is on the fuse block. (There should be 2 of them. One is for hazard lights.)
    Check fuses also.
    I have diagrams in my old Haynes manual but I won't be able to post them until next week.
    Welcome and good luck!
  4. Zspoiler
    Zspoiler Veteran Member
    3,302
    272
    May 6, 2012
    Federal Way, Washington
    Look up 1981 Camaro fuse block diagram on google There should be a diagram .And if you don`t have a printer .Go to your public library and have one made. Then check your fuses. I have a 1979 Camaro Z-28 RS,And a 1981 El Camino SS. I had that issue with my El Camino .And it was just the fuse.And if it has an earlier column the dimmer switch should be on the floor.If they did it correctly.Good luck to you.
  5. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    Thanks guys. I'm pretty sure I read that the 81 has the dimmer on the column.... It's definitely not on the floor. I will google this fuse block diagram. was just looking for some sticky or resource on here. I really hate what photobucket has done btw....
  6. Scott51
    Scott51 Veteran Member
    629
    74
    Jan 2, 2012
    New Zealand
    54baker likes this.
  7. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
  8. FlaJunkie
    6,271
    185
    Mar 24, 2001
    Rockledge, Florida
    Maybe it is just out of blinker fluid? (Couldn't resist!) :crazy:
    Rjgearhead, 54baker and 80sz like this.
  9. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    floor mount dimmer switches accumulate a ton of crap in them over the years and they rust internally causes intermittent or permanent problems. For $10 replace the dimmer switch before you do anything else.
  10. Rogerzz
    Rogerzz Member
    35
    Mar 28, 2018
    The dimmer is on the floor of the 81. I have also the 81 look under the carpet. It should be in the top left corner. Never heard or seen it on the column.
