Recently bought an 81 Z28. No blinkers. No dimmer.
Discussion in 'Electrical Systems' started by 54baker, Aug 25, 2017.
  1. Coadster32
    1,681
    137
    Oct 2, 2013
    Milford,CT
    I replaced mine in my 79. Made a big difference, and yes...the switch was shot.
  2. phat80
    phat80 Veteran Member
    1,021
    13
    Jan 4, 2013
    Victoria BC
    A common issue is the carpet underlay will accumulate under the dimmer switch push button and then you can't press it down to switch from HB to LB. If the wires are corroded it will also affect blinkers.
    Best bang for your buck: go to www.ClassicCarWiring.com and order their 1981 Camaro color coded wiring diagram. Best money you'll spend.
  3. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    2,382
    82
    Feb 2, 2008
    SF
    If it’s on the column it’s probably not a camaro then
  4. 8pack
    2,622
    149
    Aug 29, 2007
    Western, MA
    I will vouch for that. Just got mine for my ‘78. Great product and only $20 shipped.
