Rechrome ac vents - what to use?
Discussion in 'Interior Restoration' started by Chuck71RS, Mar 10, 2019.
  1. Chuck71RS
    1,333
    138
    Nov 24, 2012
    Houston, Texas
    Is there something I can buy to do this? Is there a dipping process?
    The chrome section will be separated from the surrounding casing and the vent slats inside the chrome coated section will be removed.
    On a junk one, the casing halves pulled apart. Removed the slats assembly from the chrome housing by grinding and drilling out 4 very small rivets with a Dremel. Install will be with #4 machine screws
  2. 70 Proof
    70 Proof Veteran Member
    494
    47
    Sep 28, 2014
    Southern Utah
    Chuck
    An internet search should come up with several hits. For a DIY project Alclad has a You tube vidio talking about using their product "Alclad II Lacquer Chrome"
    Also you can check out GCar website as an additional source for plastic rechroming.
  3. CDesperado
    3,389
    25
    Oct 1, 2004
    Dallas Texas
    I used a company to do so some plastic re-chroming for a few items. It wasnt cheap, but they did a fantastic job. The one thing to note is that I am not sure if they can chrome just the outer edges like OEM. In my case they chromed the entire piece.
  4. 70lt1z28
    2,911
    472
    Oct 3, 1999
    Beavercreek, Ohio, USA
  5. CDesperado
    3,389
    25
    Oct 1, 2004
    Dallas Texas
    This is the company I used: Layson's Restoration. The offer a plastic re-chroming service, but I dont know if they can chrome only a portion of the item. There was a bit of a wait, but I would use them again in a heartbeat.
    http://www.laysons.com/CatalogMenu.cfm?nCatID=90
  6. ronzz572
    1,929
    52
    Feb 8, 2007
    imperial pa
    I have seen people use the reproduction vents and move the original vent doors. You can remove the plastic welds and reweld glue them into the new reproduction chrome housings. I have not personally done it. But it's a alternative to rechroming. You will have to disassemble them anyway to get the originals chromed.
  7. bkmont
    bkmont Veteran Member
    1,091
    44
    Nov 14, 2010
    Pensacola, Florida
    I used a two step paint process made by Spaz to redo my 68 GTO's dash chrome accent - IMG_0530.JPG
  8. 70lt1z28
    2,911
    472
    Oct 3, 1999
    Rick Nelson did this on a 70Z restoration.
    Photos start here:
    https://www.facebook.com/112534525437660/photos/a.163437033680742/607708239253617/?type=3&theater
    The 70's were the only ones with smooth vanes. The OER repops which are good otherwise have the 71-later textured vanes.
  9. Chuck71RS
    1,333
    138
    Nov 24, 2012
    Houston, Texas
    Thanks for the ideas. The chrome finish will be stripped and painted SEM Landau Black as is the rest of the vent. A chrome finish does not appeal to me, especially at the two center dash vents having three colors (dash, chrome and black). For uniformity, with the center vents all black the outer vents need to be all black.
  10. Revin
    Revin Veteran Member
    511
    75
    Aug 31, 2016
    Round Rock , TEXAS
    Wonder if they can wrap the chrome?
