Recommended cfm carburetor for a stock 305 V8 engine?
Discussion in 'Engine Topic' started by golfer, Feb 16, 2011.
  1. golfer
    golfer Member
    42
    Jan 29, 2006
    What brand carburetor and what size in cfm will perform nicely for a 76 stock 305 V8 to be used mainly for a daily driver?
    Rebuilding the original Rochester is an option.
  2. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    I would almost never suggest a Qjet but on a stock engine, I think that's going to be your best bet. You don't have to guess and check on jetting or bleed sizes or anything when the factory did that work for you. The qjet, rebuilt properly, should get the best MPG and have the best throttle response on that setup.
  3. marlin
    marlin Veteran Member
    242
    Oct 27, 2009
    Wantagh, NY
    Q jet for sure, Summit and Jeg's have rebuilts for sale as well.
  4. 78TypeLTCamaro
    78TypeLTCamaro Veteran Member Gold Member
    485
    12
    Mar 2, 2001
    Waltham, MA. USA
    I just had my Rochester rebuilt for my 305. For an unmodified or slightly modified 305 that has the 2bbl manifold I don't think you can do any better with the stock 2bbl carb.
    If you replaced the manifold with one for a 4bbl, sorry I would not know the best.
  5. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    My car came with a 305 when I bought it. It had an Eddy intake with a Holley 600cfm four barrel and it ran just fine.
  6. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    I'd recommend a 750 cfm carb,,,,, as long as it is a Q-Jet.
    You could find a 390 holley economaster, that's about all a 305 needs.
  7. sweetsoul
    sweetsoul Veteran Member
    598
    Jan 12, 2010
    Liberty sc
    rochester 2g 2 barrel.......just kidding , get a good dual plane intake and a 600 holley.you will be happy!
  8. 67 C-4 Camaro
    67 C-4 Camaro New Member
    Feb 14, 2011
    Wash DC
    The rochester has problems when the secondaries kick in cause they are vac operated. I used to use a holly 600 with vac secondaries. This actually gave better fuel economy. Anything over 600 cfm is a waste of gas on that engine. Also don't be affraid to adjust your mechanical timing to 4 btdc. Smog era engines were retarded to help pass emission tests back then.
  9. SS2001
    SS2001 Veteran Member
    530
    Jan 4, 2008
    Lithia Springs, GA
    I would run more timing than that.
  10. my24ktrat
    my24ktrat Veteran Member
    1,226
    Jul 5, 2007
    Roch., NY
    ...As others have stated , either the quadrajet or a Holley 600, whatever is cheaper in your budget, just not the stock 2bbl , just my.02, DC:bowtie:
