Recommended cfm carburetor for a stock 305 V8 engine?
Discussion in 'Engine Topic' started by golfer, Feb 16, 2011.
  1. 5spd540
    12,365
    13
    Sep 19, 2009
    Guyton, GA
    Factory q jet then a eddy 600
  2. DoTheDew
    DoTheDew Veteran Member
    899
    Mar 2, 2010
    Leduc, Alberta
    I run a 600 eddy with no problems. However, if I had the option and were in the market, I'd opt for a 500 eddy. 600 is more than enough for a 350, and if you do the math for a 305, it works out to 470ish cfm, unless you have afr heads or something similar.
    I'd also run more timing. If its a smog era 305, you can get away with a lot of timing due to the low compression. It'll really wake it up. I run 20 intial, and have the lightest springs, and its a whole other engine.
  3. 1980RS
    1980RS Veteran Member
    3,152
    507
    Jun 17, 2006
    MN
    1406 eddy would work just fine on a 305 as they are a little too lean out of the box for a 350.
  4. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    500 eddy
  5. MartinD
    MartinD Veteran Member
    124
    Nov 18, 2005
    South Georgia
    If the TOP flaps are not opening, adjust the tension spring.The actual secondary flaps are semi mechanical
