Recovering from total knee replacement surgery again
Discussion in 'The BS Topic' started by muscl car, Oct 9, 2019.
  1. Fbird
    3,887
    603
    Feb 12, 2011
    atlanta, ga
    I refuse to go there... about 6 hacks on my left knee and 2 on the right......learned running is not for humans.... I only have to run about 20 ft...to my pistol ;)
    hope they set the toe in correct!!! camber will scrub in..
    good luck with the recovery
  2. Knuckle Dragger
    14,704
    1,267
    Nov 2, 2002
    Waddell AZ
    That's a big scar man. I guess they have to lay it all open. For the rod in my femur I just got two three inch scars. I hope it doesn't hurt as much as it looks like it should :)
  3. muscl car
    21,641
    611
    Jul 8, 2001
    High Desert of Hesperia Calif
    There's 68 staples to close the Surgical site , normal knee replacement scar is midline ( down the center) . Mine had to be in this location because of an old ACL repair in 1982 . This side of the knee has alot blood flow from veins located there
    If they would have done a normal midline incision the skin would die from lack of blood flow
    A Marine friend of mine said that scar would make for an awesome tattoo !!!!! .he said a Tatto with a K bar knife with blood dripping and the words " pain is weakness leaving the body " would be awesome
  4. xten
    xten Veteran Member
    2,812
    1,575
    Sep 24, 2014
    Pittsburgh, Pa.
    Guy I know had open heart, scar right down the center. He had a tat of a zipper put over it. His dr. flipped $hit.
  5. muscl car
    21,641
    611
    Jul 8, 2001
    A zipper tat would look awesome !!!!
  6. danbrennan
    danbrennan Veteran Member Lifetime Gold Member
    3,519
    287
    Mar 13, 1999
    Brighton, MI
    I hope the recovery goes well for you. My wife has an artificial knee in both legs, the recovery was hard for her.
  7. muscl car
    21,641
    611
    Jul 8, 2001
    Just got back from PT where I'm now pulling to 97┬░ and 0┬░extension
    carr911 likes this.
  8. carr911
    carr911 Veteran Member
    1,709
    361
    Mar 4, 2016
    Tampa, FL
    this is how it's done!
  9. muscl car
    21,641
    611
    Jul 8, 2001
    Reached another goal today , just went 1.5 miles on a recumbent bike !!!!! . That took almost all my energy and and I'm drained but happy what I accomplished
    Da-bigguy, xten and carr911 like this.
  10. carr911
    1,709
    361
    Mar 4, 2016
    Tampa, FL
    keep up the Good Therapy!
    Got a question on the "re-shimming" did they replace the Delrin Pads or was or leg not aligned correctly?
    muscl car likes this.
