Reinforcement bracket where e-brake cable passes through floor
Discussion in 'Body Restoration' started by drummingrocks, Oct 12, 2019.
  1. drummingrocks
    drummingrocks New Member
    Oct 6, 2019
    I've replaced the inner rocker, toe boards, and part of the driver's front floor pan on my '80 Camaro due to rust. When I started, the area where the e-brake cable passes through the floorpan was completely rotted out. I could tell that there was some kind of reinforcement bracket welded to the floorpan to reinforce the area where the cable passes through, but it was too far gone to use as a template to make a new one.
    I can't find where that bracket is reproduced. Can anyone post some pictures of that area from underneath the car? As best I can tell, it's an L-shaped bracket that spot welds to the driver's floorpan. Thanks!
