Removal of dip stick tube?
Discussion in 'Tips 'n' Tricks Topic' started by Rugratman, Mar 9, 2019.
  1. Rugratman
    Rugratman New Member
    29
    Oct 25, 2018
    Any tips? I have headers installed. Everything is all painted and pretty.
    Plyers are not moving it all.
  2. Gary S
    22,125
    659
    Spray it with penetrating oil first. Then wrap it with a cloth so you don't damage it with a pliers. Using the pliers and your hand gently rock and twist it while pulling upward. If you are lucky, it will start to move.
  3. COPO
    17,468
    587
    Just curious, why.
  4. 70lt1z28
    3,126
    584
    Oct 3, 1999
    Beavercreek, Ohio, USA
  5. Rugratman
    29
    Oct 25, 2018
    I went on You Tube to research it and all the tips were for removing a broken one.
    Well guess what, I broke it off. Seems they break pretty damn easy.
    After allot of cussing I used a #6 easy out. Did the trick.
    New one is installed.
    The previous owner installed a Passenger side dipstick instead of a drivers dipstick.
    Thanks guys hope this helps.
    NOTE: for future reference a #6 easy out made it easy.
