removal of fact am/fm radio 1972
Discussion in 'Tips 'n' Tricks Topic' started by mikess68, Feb 14, 2020.
  1. mikess68
    mikess68 been there and back
    13
    15
    Jan 16, 2019
    portland, tn
    just need some info to not totally disassemble the dash/car etc. just need to remove the radio and get it checked/repaired. does it come out the glove box area or do I have to remove the console? whats the path I need to go after? thanks!
  2. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,269
    54
    Jan 1, 2005
    Schererville,In.46375
    Remove the glove box insert, and the side brace on the drivers side. The radio should drop down and slide out the passenger side. Maybe think of rebuilding the front speaker at this time if it hasn’t been already.
  3. mikess68
    13
    15
    Jan 16, 2019
    portland, tn
    ok, any trick about the ant, like is there enough slack to unplug without damage to the wire going to the glass? I also think I will replace the speaker while im at it.
  4. Twisted_Metal
    27,159
    1,049
    You can unplug the antenna once you can reach the back of the radio.
    Shouldn’t be hard to unplug that.
    There’s usually a stud or bolt on the back holding it to a bracket too.
    I swap stereos with the console out and the glove box in place.
    But mine is an 80 and the console is different. I’ve never removed the console on an early 2nd gen.
  5. Gary S
    22,655
    832
    On my '70, all I have to do is remove the one bolt that holds the bracket and the two front knobs and umplug the wiring. Then it drops out the bottom of the dash, but I don't have a console to work around.
