Removing front subframe
Discussion in 'Body Restoration' started by jester0618, Dec 14, 2015.
  1. jester0618
    jester0618 Veteran Member
    271
    26
    Dec 6, 2015
    Bryan, OH
    Ok, I've got the car on jack stands, front under the subframe, axle for rear. Once I pull the engine/trans, where should I move the jacks to for subframe removal? Any pics would be great.....
    TIA!
    Jeff
  2. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    I recall just placing jack stands on the braces under the floor pans to support the shell. Then I had two jacks, one for the front and one for the rear of the sub frame. I supported the sub frame with 4x4 pieces that were the exact width of the sub frame.
  3. jester0618
    271
    26
    Dec 6, 2015
    Bryan, OH
    Thanks Aaron, just finished checking your build out. My Nova was black. won't ever do that again LOL. I didn't paint it though. Maybe I can get better. Wife won't let me take her Mustang out of the garage to do mine so I have to drive to get to the car work. Maybe someday.
  4. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    Check out my thread. I placed 2x4's under the rockers and set them on jack stands to support the shell.
  5. jester0618
    271
    26
    Dec 6, 2015
    Bryan, OH
    I was unable to find your thread. Can you link to it please?
  6. grzewnicki
    3,342
    125
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I just put my jacks under the rockers with some wood on top to keep from denting the bottom of the rockers, but as light as an empty body is that probably wasn't necessary. I left the front tires sitting on the ground, unbolted the frame from the car while laying under it and holding the rear of it up with one hand, resting on the front tires the rear of the frame weighs nothing really.
  7. kevprue21
    kevprue21 Member
    39
    Mar 16, 2011
    North alabama
    Sounds like they have sent you the right way.
  8. jester0618
    271
    26
    Dec 6, 2015
    Bryan, OH
    I'll have to give that a try. The jacks I have under it now raise the tires off the ground. Was thinking using the cherry picker to hold the front up, but I like your idea/method better. Less to slip and fall on me that way.
    Thanks!
  9. CAMeeks
    CAMeeks Veteran Member
    691
    34
    Jan 5, 2014
    Deer Park, TX
    Here is how I did it. I also added 2 more 4x4 to connect to the rear mounting points.
