Removing seatbelts from floor
Discussion in 'Tips 'n' Tricks Topic' started by 79camaro dad, Apr 3, 2018.
  1. 79camaro dad
    79camaro dad Member
    47
    Mar 16, 2017
    What' the best way to remove seatbelt bolts from floor. Mine are so tight I keep breaking sockets
  2. CorkyE
    10,381
    472
    Impact wrench. I've also used one of those drivers that you smack with a hammer to break mine loose.
    Have you tried PB Blaster or anything like that? I use a 50/50 mixture of ATF and acetone.
  3. Zspoiler
    Zspoiler Veteran Member
    3,267
    266
    May 6, 2012
    Federal Way, Washington
    Use a lubricant like WD-40 or some kind of oil and a 1/2 drive wrench and or breaker bar.
  4. xten
    xten Veteran Member
    2,948
    1,720
    Sep 24, 2014
    Pittsburgh, Pa.
    Any kind of weazle pee from underneath and let them sit for a while. Then try to break them loose.
  5. Plater Tom
    Plater Tom Veteran Member
    1,393
    23
    Feb 2, 2003
    Mt Pleasant, Pa. USA
    Use a propane torch to get rid of all the crud that has accumulated on the threads under the car, Then use a air wrench.
  6. 79camaro dad
    79camaro dad Member
    47
    Mar 16, 2017
    Thanks everyone
  7. Rayden2009
    Rayden2009 Veteran Member Gold Member
    111
    14
    May 12, 2016
    Calgary AB
    PB Blaster and Torch was how I did it. It took several attempts over several days. The back seat bolts were the worst, and the Trorx head is super prone to stripping. I did get the bolts loose eventually. I couldnt imagine getting them out without the torch.
  8. badslife2
    badslife2 Veteran Member
    491
    Nov 11, 2001
    Saginaw,MI
    I welded a nut over the stripped out Torx head.
  9. Gary S
    22,586
    808
    Your name suggests you are working on a '79 model. If so, you likely have torx bolts holding the seatbelts in place. If so, you have a difficult job ahead of you. The early cars used hex head bolts and those can be easily removed with a ratchet and socket. The torx bolts are a nasty design failure.
    Try some of the tips posted here. Once you get them out, you might be able to weld a better head on them for future use.
  10. steve78LT
    steve78LT Veteran Member
    250
    Nov 30, 2003
    Barre, MA, USA
    This worked for me too. Had my kid hold the torch on the underside and kept pressure on the socket until it turned.
