Removing seatbelts from floor
Discussion in 'Tips 'n' Tricks Topic' started by 79camaro dad, Apr 3, 2018.
  1. CamaroDoc
    CamaroDoc Veteran Member
    2,011
    111
    Sep 13, 2003
    Skiatook, Okla. 74070
    Another option for stripped splines on the torx bolts... You can get impact sockets for removing wheel locks when you don't have the key. They bite into the outer edge of the bolt heads instead. Best advice is to use a good quality torx bit so you don't strip out the torx splines in the first place. Also, I always break them loose with a 1/2" breaker bar by hand before hitting them with an impact.
