Removing the hard seam sealer
Discussion in 'Body Restoration' started by Mr Sunshine, Jan 22, 2018.
  1. 1978 Z/28
    1978 Z/28 Member Gold Member
    96
    22
    Jul 17, 2017
    New Brunswick
    I would be a bit worried about the fumes. the HF tool can be used a round the home also great for cutting into sheet rock
  2. GoldenOne7710
    4,768
    377
    Jun 23, 2004
    Athens, GA
    I used a wire wheel on a drill with excellent results. Replaced it all with modern urethane seam sealer, let it set up and repainted the firewall with some high temp epoxy.
  3. Mr Sunshine
    Mr Sunshine Member
    91
    Dec 12, 2016
    Missouri
    Got the old seam sealer removed today from the entire firewall & cowl. I used a heat gun, scraper and wire wheel on a 4" grinder in that order. Worked really well.
    Actually a pretty good way to spend a Saturday afternoon while listening to some Tom Petty. Had a productive day.
  4. budro6968
    budro6968 Veteran Member
    3,143
    490
    Apr 2, 2016
    Jax Florida
    That H/F tool is great. I burned one up under warranty. Got the second and have had it for 5 yrs. I always run any electric tool from H/F full blast for a couple mins now before I used them. Let them cool and I have had good luck. I think the brushes need to get seated. I usually blow them out with compressed air when done too.
  5. Desert_Dick72SS
    Desert_Dick72SS Veteran Member
    197
    Feb 10, 2009
    San Francisco Bay Area
    I've always used a wire wheel/air-powered die grinder...cleans up just about anything.
    ...Hate picking the wheel's wires outta my forehead though...
    -Rich
  6. Mr Sunshine
    Mr Sunshine Member
    91
    Dec 12, 2016
    Missouri
    Yep I was picking those things out of my shirt all afternoon.
