Replacement Radio
Discussion in 'Car Audio, Electronics & Security' started by BigBlock73, Dec 5, 2017.
  1. BigBlock73
    2,015
    59
    Jul 10, 2002
    Accord,New York
  2. tom3
    tom3 Veteran Member
    11,862
    317
    Aug 1, 1999
    ohio
    Windshield antenna is usually pretty decent for FM, I'd suspect a weak radio. That unit in Crutchfield sure looks interesting, and they know how to make their stuff fit and work, but that sure is a lot of money, and probaby several bucks more for the fit up items. Might be the only thing available though.
  3. 70 Proof
    70 Proof Veteran Member
    534
    54
    Sep 28, 2014
    Southern Utah
    Until you get a replacement radio you might be able to improve the poor reception problem with your current radio by checking to see if the windshield antenna plug in connection at the bottom center of your windshield is clean and tight.
    Big Block Z likes this.
  4. PalmbchZ28
    PalmbchZ28 Veteran Member Gold Member
    759
    322
    Jan 29, 2017
    West Palm Beach Fl
    classiccarstereos.com/custom-autosound.html. I have these in 2 cars and really like them.
  5. BigBlock73
    2,015
    59
    Jul 10, 2002
    Accord,New York
    Tom
    That radio seems to come with anything that might be needed to mount it.
    I'm thinking of buying another lower dash that is already cut to mount a different radio, but I want to keep the retro look of the stock interior.
    70
    I had the windshield replaced 2 years ago and made sure the connection was good and clean.
    Still might be a bad cable,will check during replacement.
    Palm
    The Bluetooth ready one's are pricey
    Thanks for all the idea's
  6. COPO
    17,639
    653
    My aftermarket radio works great with the windshield antenna.
  7. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
  8. 78TypeLTCamaro
    78TypeLTCamaro Veteran Member Gold Member
    485
    12
    Mar 2, 2001
    Waltham, MA. USA
    I installed that one in my 78 Cutlass which has a windshield antenna. There are no problems with reception. No problems with the radio and the features are worth the price.
  9. 70lt1z28
    70lt1z28 Veteran Member
    3,261
    636
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I went with a original radio rebuild from Precision Radio Repair:
    https://www.hemmings.com/magazine/mus/2009/11/We-ve-Got-the-Jack/2292821.htmlwhere
    where Bob installed a 3.5mm jack. I will then use a bluetooth adapter like this:
    https://www.newegg.com/Product/Prod...qDP_zsNkFbe5cjbGgbhoCqw4QAvD_BwE&gclsrc=aw.ds
    to pair with my phone. It's not going to be a high end sound, even though Bob improves the stock radio with better components. The stock radio is mono anyway. I would rather listen to the engine anyway. If your car is a driver and you don't care if it looks stock (I do)you may want to just upgrade. It would be cheaper.
    There is a trimmer adjustment for the antenna. You tune the radio to a certain frequency and then there an adjustment screw under one of the knobs. Adjust it till it has the best reception. How to do is here:
    http://www.chevelles.com/radiotech/reception.html
  10. Burd
    589
    101
    Oct 6, 2011
    I helped my bud put a new replacement in his 70, it had jacks on the back, not sure on Bluetooth,
    At the big swap in Jan here a guy had a nos one still shrunk wrapped on a cardboard, I didn't buy it, something looked wring, I would think they would come in a box. It was a 78 am/fm 8 track.
