Replacement studs for '80 trunk spoiler?
Discussion in 'Body Restoration' started by drummingrocks, Oct 19, 2019.
  1. drummingrocks
    drummingrocks New Member
    Oct 6, 2019
    I'm installing a rear spoiler on my '80 Camaro. I have all of the factory parts, but the spoiler and endcaps are missing some studs. Does anyone know where I can get replacement studs?
    I see where the mounting nuts for the spoiler are reproduced, but the only studs I can find are they ones they reproduce for a '67-69 Camaro. Any chance those would work, or is my only option to find someone who's willing to pull some studs out of a factory '80 spoiler?
    Thanks!
  2. badazz81z28
    16,586
    438
    Las Vegas, NV
    Having looked a few years ago, no reproduction studs. Best is to find a trashed spoiler.
  3. Zspoiler
    Zspoiler Veteran Member
    3,211
    251
    May 6, 2012
    Federal Way, Washington
    And or make up your own by using thread stock.
  4. wnmech
    wnmech Veteran Member
    925
    81
    Jul 20, 2014
    grand prairie tx.
    I did what zspoiler did. I don’t remember the bolt sizes anymore but I just bought common long enough bolts and cut the heads off and filed the cut off end to a taper and ran the nuts from the opposite end enough to cut the thread and they are workin perfect.
  5. GoldenOne7710
    4,767
    377
    Jun 23, 2004
    Athens, GA
    If there's an Ace Hardware store in close proximity, I'd take a look at what they have. Mine has one of the best assortments of fastener hardware I've ever seen...including studs of various lengths and sizes.
  6. Bandit723
    Bandit723 Veteran Member
    3,148
    462
    Oct 1, 2016
    Waupaca WI
    I went with a donor spoiler probably not the cheapest route but i got what i wanted.
  7. Twisted_Metal
    26,948
    925
    Those are 1/4" inch standard threads that go through the trunk lid... Right?
    Couldn't you use that size all-thread rod and put the same size helicoil into the spoiler?
  8. larrylarry
    larrylarry Veteran Member
    1,544
    70
    Dec 22, 2011
    San Antonio Tx
    1/4 in. Bolts, cut the hex head off & don’t make them to short & cut new threads in the spoiler & put glue on threads & your done.
    Twisted_Metal likes this.
  9. JumpMaster82d
    JumpMaster82d Member
    43
    Mar 14, 2016
    Central NC
    Buy the 67-69 kit, they are the same except a few are too long, just chop them off and your set. That's what I did anyway.
  10. badazz81z28
    16,586
    438
    Las Vegas, NV
    Which end is long?
