Replacing quarter panels
Discussion in 'Body Restoration' started by Goat, Jun 14, 2019.
  1. Goat
    1,883
    39
    Jun 7, 2001
    moncure, NC
    How hard is it? I know this is a very broad/loaded question, but is this something a novice can do? Once everything is down to bare metal, will it be apparent where edges should meet and such? This adventure would be using NOS sheet metal. Probably a better fit - but also don't want to $uck up an expensive panel. The intent would be to spot weld it in place and let a pro finish it...
  2. xten
    xten Veteran Member
    2,369
    1,172
    Sep 24, 2014
    Pittsburgh, Pa.
    Yes, that is a broad/loaded question. lol. Do you think you may need related parts? Drop offs? outer wheel houses? How's the rear body panel? Even if you are a good (structural) welder, sheet metal is a different animal. Is this on a 2nd gen?
    hubedobeedo likes this.
  3. hubedobeedo
    hubedobeedo 3rd times a charm
    289
    69
    Jul 18, 2013
    Huntertown,IN
    not something to rush into if not had experience with that type of replacement. theoretically any body could do it .there is alot to take into consideration before, during and after the task will be completed. xten is right about taking slow ,figure out as much as can before getting out the cutters.could you post pics of inside and out of 1/4 ,curious as to how "bad" it is
  4. Goat
    1,883
    39
    Jun 7, 2001
    moncure, NC
    Thanks for the replies. This is still a ways off if at all. just trying put together a plan...
  5. xten
    xten Veteran Member
    2,369
    1,172
    Sep 24, 2014
    Pittsburgh, Pa.
    Good idea. You will need a plan of attack. Is this a 2nd gen? Your concern is understandable with NOS stuff. Hard to come by and expensive. Look at the attachment points, see what kind of shape they're in. Take some pics and maybe post a few.
  6. Goat
    1,883
    39
    Jun 7, 2001
    moncure, NC
    Yes, late 2nd gen...
  7. Revin
    Revin Veteran Member
    512
    75
    Aug 31, 2016
    Round Rock , TEXAS
    Not bad to get done. watch some videos, your welding skills? have a flange tool? body work skills?
    hold up new panel to body and outline it.
    cut about 1-2" below that so you have some wiggle room. this will just get the bulk of both out of the way for better look at project.
    I leaded the roof to top of panel to quatrer, look into that as well.
    Flange tool makes nice little ledge and panel will fit like glove together.
    hardest part is the taillight panel. it and quarter are press welded together and can be a pain to redo. (I cheated and smoothed all seams)
    Yes the drop off panel may need replacing and inner wheel tub(or add a mini tub at that time)
    You will never know untill you TRY IT. ;)
