Restore your hub caps
Discussion in 'Tips 'n' Tricks Topic' started by berg2695, Jun 11, 2019.
  1. berg2695
    berg2695 Veteran Member
    275
    51
    Nov 13, 2011
    AUBURN, WA
    I stumbled onto a trick to make it easier to polish up the center caps on our 5-spoke steel wheels. All it takes is a trip to the plumbing section with a side trip to the nut and bolt department.
    20190611_143315.jpg 20190611_143543.jpg 20190611_144003.jpg After body working any dents and dings, now you can comfortably sand with increasingly fine grits, just like color sanding. Use the palm of your hand for the face, and fingers for the side. Factory caps are stainless, not chrome, so have no fear. Put a pan of water on the drill table and wet sand, even. Oh... maybe put some tape around the tangs on the back of the center cap so they can't grab your polishing cloth (or your skin). When you are done they may look so good you are forced to paint your wheels (like olstyle!) or get new lug nuts.
  2. Scott Sievers
    Scott Sievers Veteran Member
    209
    95
    May 22, 2018
    SE Iowa
    NICE!!!!
  3. berg2695
    275
    51
    Nov 13, 2011
    AUBURN, WA
    Thanks Scott!
  4. RS1979
    3,760
    751
    Jun 18, 2013
    Memphis, TN
    That looks awesome
  5. 70-camaro
    70-camaro Veteran Member
    2,392
    443
    Mar 25, 2010
    marietta ohio
    Real good idea!! The only thing I see for safety would be to replace the wing nut with a hex nut.
    berg2695 likes this.
  6. berg2695
    275
    51
    Nov 13, 2011
    AUBURN, WA
    If you are like me and your car project is moving at glacial speed: you get a frame at the thrift store, put a piece of foam rubber in it to stick the tangs into and put it on the wall for inspiration. 20190617_102809.jpg
    70-camaro likes this.
