Reuse Original upper and lower balljoints
Discussion in 'Original Drivetrain Topic' started by 70-SS/RS-L78, Nov 19, 2019.
  1. 70-SS/RS-L78
    70-SS/RS-L78 Veteran Member Lifetime Gold Member
    2,654
    47
    Mar 19, 2003
    Phila area
    I was wondering what people do when restoring a car and the ball joints are like new. The born with upper and lower ball joints in my car are in fantastic shape, They are real tight with absolutely no play in them at all. The car was undercoated by a seriously generous new car prep guy so they even look great. He undercoated everything, and I do mean everything. he slammed at least an inch or two of that crap on the upper and lower control arms, inside and out. Now I know why the front and rear springs were lazy. The car was 50 pounds heavier due to all of the tar like substance all over the bottom of this car. I will replace the bushings even though I don't see any cracks in the rubber. Now the search begins for a set of OEM bushings.
    Mark
  2. Zspoiler
    Zspoiler Veteran Member
    3,271
    266
    May 6, 2012
    Federal Way, Washington
    Its just better to replace it all when restoring a car. Because it could be in the back of your mind that even it appears to be in good shape .The mileage could get you. especially if you upgrade the power train and suspension on the car.
    hubedobeedo likes this.
  3. l16pilot
    1,847
    138
    Dec 13, 2004
    Hurlock, MD, USA
    Mark,
    If the ball joints are tight, then there really is no reason to replace. The bushings are a different story as the rubber does age due to exposure, so good to replace the bushings.
  4. ronzz572
    2,067
    92
    Feb 8, 2007
    imperial pa
    Mark, I'm and in the middle of making the same decision. My L78 upper and lower ball joints are in very nice condition. I am going to recondition clean my original up. More than likely re use them. Bushings are all going to be replaced.
  5. 70-SS/RS-L78
    2,654
    47
    Mar 19, 2003
    Phila area
    ron I am going to leave them alone, first I would have to find a set, I'm sure I would have to pay a small fortune for them when that money could be spent on other things. besides this car will lead a pampered life anyway. Thanks...
    Mark
  6. 70 SS/L78
    2,750
    105
    May 5, 2005
    Rockford, MN
    Mark, I would definitely leave your upper BJ alone. Especially since they are tight and boots are still good. Even the lowers to if they're not to rusty. Just clean them the best you can and put something on them to protect from rust.
    I would like to see some pictures of the original rivets (both sides) to compare to the ones I have been replacing for others here.
  7. flowjoe
    7,977
    29
    Feb 7, 2006
    SoCal
    The problem I’ve found, Steve, is that current replacement bushings are made of crappy rubber that deteriates quickly. It seems to be across brands and parts (bushings, vacuum caps/plugs, etc). While I’m with you on replacing old bushings I’d be reluctant to count on them being the last set the car will ever need - even with pampered usage.
  8. l16pilot
    1,847
    138
    Dec 13, 2004
    Hurlock, MD, USA
    Agreed Joe, When I did my bushings, I sourced old-er Moog units with boxes dated in the early 80s. The rubber looks and feels good, so hopefully they'll last a little while. I'm also counting on our climate not being nearly as harsh on rubber and polymers as yours to help them live longer ;)
  9. 70-SS/RS-L78
    2,654
    47
    Mar 19, 2003
    Phila area
    Scott I will take some pictures of the rivits. The lower ball joints are tight also. I will clean them up and see
    how they look. Thanks...
    Mark
  10. restore-z28
    restore-z28 Veteran Member
    417
    66
    Jul 4, 2010
    Vancouver, BC
    Hey Mark,
    As yours are still tight, for the uppers I would clean them up as best as you can but for your lowers, I would just press them out, clean them, soak them in Evaporust, coat them in Boeshield and reinstall. As the upper are riveted in just soak the ends of the control arms in Evaporust and coat them. BTW the lowers took me about 5 mins to press out, and about 4 1/2 minutes was setting up the tool...they will also press back in with no issues or damage to the lower balljoint.
