Ring Brothers 2nd Gen Billet Door Hinges NOW AVAILABLE
Discussion in 'Body Restoration' started by gmagno, Mar 27, 2012.
  1. Polanjl
    Polanjl Veteran Member Lifetime Gold Member
    202
    Jul 27, 2012
    San Antonio, TX
    If you look at the picture of the hinge you'll see round divots close to where the pin goes though the hinge. The divots are for a pin or a ball bearing with a spring or something that pushes down on it to sit in the holes to hold the door open. If you look at the second picture you can see two small screws that hold a cover and I'm sure if you took that off you would be able to see the pins/spring that will hold the door open.
  2. Bandit723
    Bandit723 Veteran Member
    3,150
    464
    Oct 1, 2016
    Waupaca WI
    Caught this thread this morning just for the fact i received an email from RingBros saying there door hinges are now in stock. Went out the the website and still the stuff is out of stock. Moving on
  3. KJZ28
    KJZ28 Veteran Member Lifetime Gold Member
    3,134
    Sep 26, 2004
    Brewsterico, New Fail
    Those look like they will never sag, nice!
  4. 70lt1z28
    3,534
    717
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Nice, but for that money I'll just rework mine with inserting drill bushings and a drill blank for the pin. I can upsize the components slightly and they will never wear out. At least it sounds simple......
