Roller Cam
Discussion in 'Engine Topic' started by Kskevin, Feb 21, 2019.
  1. COPO
    17,446
    572
    My Stuff I used.
    Dist gear - Lunati 89027 (.491)
    Fuel pump rod - Lunati 94607 (5.750)
    Lifters - Lunati 72330-16 retro
    Push Rods - Comp 7608-16 7.200 (these are 1 piece hardened for my guide plates). I first had Melling 25733-16 and they were not hardened as stated.
    Timing set/chain - Double true roller - Lunati Adj Timing Set 95100 (Cloyes)
    Valve spring retainers - Lunati 75742-16 (1.250 11/32)
    Valve springs - Lunati 73943K1 (1.260") per cam kit
    Valves - Manley Stainless steel - Intake-10766 Exhaust-10765
    Pistons - Mahle Forged 40 over SBC550040F05 14730_02
  2. Kskevin
    Kskevin Member
    42
    Feb 6, 2019
    Thanks that makes it alot easier
  3. BonzoHansen
    19,246
    679
    Jun 1, 2005
    Scott from Hamilton, NJ
    if lunati says you have to you should follow them. Howard's told me no, but that's a different brand. Plus they may be talking about the cam for that block and not a retrofit cam like I'm running.
    The manufacturers know better than the Internet. :)
    Kskevin likes this.
  4. 77 cruiser
    77 cruiser Veteran Member
    530
    23
    Nov 17, 2006
    Frostbite Falls MN
    Custom cam with a iron gear on it, if you care to go that route.
