Rolling Rear Fender Lips a Good Idea?
Discussion in 'Tips 'n' Tricks Topic' started by gordonquixote, Aug 12, 2008.
  1. dcozzi
    dcozzi Veteran Member
    3,146
    445
    May 1, 2002
    Phoenix, AZ
    The "dirt basket" should drain if not crimped on the bottom. I am not a good judge of this though as I live in AZ and we get about 10 in. of rain a year.
    Just don't mud bog the Camaro:crazy:
    hubedobeedo likes this.
  2. badazz81z28
    17,083
    543
    Las Vegas, NV
    Please expand on this. Jack the car up? or let it down to create more pressure?
  3. sandiego74
    sandiego74 Veteran Member Lifetime Gold Member
    1,123
    61
    Feb 23, 2009
    San Diego, CA
    Looking into rolling my rear fenders and was curious about the price of the Eastwood tool since it’s been a while now that it’s been on the market. It isn’t now just over $80 on their website, and there are a bunch of knockoffs for $60 or less on Amazon.
    https://www.amazon.com/s?k=fender+roller&ref=is_s
    Originally, I looked up some local guy who uses the tool and charges $90 for two wheelwells, figuring that the tool was still in the triple-digit range. Glad I looked, and hope this helps others who might be interested right now.
  4. cisco 1
    cisco 1 Member
    30
    10
    Apr 14, 2019
    quebec,canada
    my 73 camaro is on the rotisserie and i wonder is i shod roll the fender before sand blast and paint unterbody . i will run 275-40-18 on 9,5 rim .
  5. budro6968
    budro6968 Veteran Member
    3,335
    543
    Apr 2, 2016
    Jax Florida
    I got in there and beat them with a ballpeen hammer. Don't have to be to fancy. just work it easy don't get wild. Does not take a whole lot to roll the edge. I had to B/C of getting side walls sliced. Also used air shocks to get the rear up.
  6. dcozzi
    3,146
    445
    May 1, 2002
    Phoenix, AZ
    I would roll them now. It will not change the exterior of the car and is easier to do safely without worrying about the paint job.
    I used a floor jack, cheater slick and a beater bat.
    hubedobeedo and sandiego74 like this.
  7. sandiego74
    1,123
    61
    Feb 23, 2009
    San Diego, CA
    Just to update, I bought the $60 tool on Amazon and it worked great. I plan on selling it now on Craigslist.
  8. Fbird
    4,129
    692
    Feb 12, 2011
    atlanta, ga
    i used a $ .30 piece of wood!.... ummm Custom fender lip tool!!!
    last one $29.99....lol
    the reason it is called rolling the fender is NOT because you are making a rolled edge but typically the manner in which it is done (quite effectively i might add ;)) is with the car in neutral you shove a ball bat or broom stick between the fender and tire....and gently ROLL the car.....letting the wood "massage" the fender lip and the tire air pressure be the "tension" ....
  9. JUNKYARD AUTOCROSSER
    JUNKYARD AUTOCROSSER New Member
    Nov 16, 2009
    Los Angeles, CA
    Hi , I took a grinder to my inner lip. There appears to be a double wall on the rear fender lip, so I took a chance and grinded the inner lip so that it is almost flush to the fender. I have been running the car like this for over 20+ years with no issues. I can take some pictures, if you are interested. I run 315x35x18 on 11" rims with 6" backspacing with minimal rubbing and no mini tubbing. My 71z28 is lowered measuring 24-5/8" inches height. Thanks and take care.
    hubedobeedo and dcozzi like this.
  10. mrfleet12
    mrfleet12 Veteran Member
    351
    110
    Aug 8, 2014
    West of Chicago IL
    Thought I'd toss this out there, this was done to my car before I bought it and most likely before it was painted.
    Did this same process to a few cars back in the day. You can't tell anything from the outside and it's easy to reverse. Screenshot_20200214-183944~2.png
